A 30 minute x-axis mod to reduce chatter
My feed rates were limited by chatter with the stock 300W spindle. I just upgraded to an 800W GMT spindle and wanted to stiffen the x-rail at the same time. I inserted M5 50mm hex cap bolts vertically in the gap between the x-axis maker slides. They are a perfect fit for the gap. I used 5 bolts spaced about every 6.25".
I used a small washer on top (any larger would interfere with the idler wheels), and used a larger washer on the bottom. It is important to use washers which will not bend into the gap when the bolt is tightened. I used extra M5 waste-board inserts as the nuts, on the bottom.
I wanted to preserve the spacing of the x-axis maker slides so that the v-wheels would track true. So I clamped the maker slides together while tightening the M5 bolts, and took care not to over-tighten. It would be easy to get carried away with the wrench and force the x-rails apart, possibly damaging them. It doesn’t take much bolt tension to get the desired stiffening effect.
The x-rail is rigid now. There is no visible x-axis deflection when I press on the spindle in any direction.
I like this chatter-reduction mod because it
  • stiffens the x-rail substantially in bending and twisting
  • preserves the x-rail spacing for the v-wheels
  • does not require dis-assembly of X-Carve
  • does not require drilling the X-Carve
  • adds only a few grams of weight
  • can be done in 30-60 minutes
  • is fully reversible
  • costs about $10 in commonly available parts
Brilliant, That’s what I’m trying to tell all this time. Those rails trying to move diagonally when forcing. I don’t think big heavy steel plate necessary. Great job.
I read your posts on this subject Alan. They inspired me to try it this way. Thanks for your insight!
I’ve been putting off the stiffening mod, I’ve only had the machine running a week or so, but I’ll be doing this version today!
Thanks,
Kelly
I did this one when it was first suggested, several months back. It works extremely well!
Me like :smile:
I swear I almost bought today press drill to do steel plate mod others did. This is brilliant way of doing this !
Saved me tons of money for sure !
Come on, go get that drill press :slight_smile:
I think I’ll give this one a try, it’s a lot cheaper than getting a piece of steel ground to the right size and no drilling required.
I love this idea and I have been ready to upgrade to a Dewalt 611 but this mod had been putting me off of the upgrade for lack of drill press and I was about to buy one of them as well to be sure the holes were done right. If this works just as well then it will save me a big headache of tearing the machine apart and potentially screwing it up. Thanks! I wish they would sell a reinforced axis now that the standard spindle is the 611.
To be honest, I found the m5 bolt to be just a hair too big. I really would have to force it between the makerslides, and I felt like that was spreading them out just a hair, which is exactly what I don’t want. I found that some 3/16" machine screws with washers and nuts fit much more cleanly. Kinda makes sense, because everyone else’s steel bar mod uses 3/16" steel stock as well.
From previous threads/posts, the gap between makerslides is 4.75mm - based on the CAD drawings. I measure an M5 bolt as being 4.86mm. That’s a difference of only 0.11mm. Not sure if I’d worry too much about that.
I agree with @AlanDavis, yesterday I cut 2 pieces of 0.093 thick 1 1/1/2" X 38" acrylic and put them between the makerslides and used furniture bolts like the others to hold it together. It worked great and there is no more flex. I like what @MattWheeler has done here, it looks easier than what I did.
I loosened the bolts that hold the slides to the end plates, dropped an M5 in next to each end plate for temporary spacing, then placed the 5 M5 bolts with washers from the top, every 6.5 inches. I started in the middle, clamped the slides together, and tightened the 5 M5 bolts/washers. Then I removed the temporary M5 bolts near the end plates, and tightened the end-plate bolts.
From what I can tell, everything it lined up nicely.
-Kelly
Just got done with mine this morning, worked like charm !
6-32 x 2 inch screws
On top nr 6 washer and nr 8 washer (anything wider wheels were pushing on X axis motor side)
On bottom side 1/8 by 1 in washers with 6-32 wing nuts.
Now Inventables stop slacking and add 5$ worth of bolts with your kits.
It might flex under heavy stress, keeping bolt and nut big enough might give more rigidity. That bolt seems a little weak, especially the Phillips head. I’d rather to use 3/16" bolt with stronger nut and head.
I know its far from perfect. One thing for sure, I was able to flex the beam on router side easily with my hands before I’m not longer able to do that with 6 bolts in place.
Thank you all for the original
mod and the variants. I ended up using eight #10-32 x 2" machine screws with round heads, and some #8 washers.
I chose that number because they came in packs of four. :wink:
Installed before my first carve. Everything is working beautifully.
Thanks for this idea! It took some time before I got around to it, but I finally stopped by the hardware store and picked up the supplies. Super simple, super cheap, super quick to do, and it made a noticeable difference in the stiffness of my gantry.
I put 10 of these across the gantry with a 90mm spacing and used nylon lock nuts and large washers to create mor of a T underneath.
Has anyone encountered any issues with this mod? What are some benefits compared to the stiffening mods?
