X Axis stiffening and Eccentric nut upgrade (Z Azis Eccentric nut to come)
Hello everyone,
here’s the mod I made today for stiffening the X-Axis and the V-Wheels mod.
1 hour of work for the moment, still need to modify the 2 Z-Axis V-Wheels as I need to find what kind of screw to use.
The mods are totally reversible, and X-Axis mod don’t need any drilling.
Eccentric nut mod are something that should be put in the assembly instruction, a real timesaver!
Below are some pic. Parts used:
For X-Axis mod:
  • Nr. 8 cap head screw M4x50
  • Nr. 16 (one on top one on the bottom) 6,3 (or 6,4) millimeter washer
For Eccentric nut:
  • Standard screw that come with the machine
  • 5,3 (or 5,4) mm washer
  • M5 nilock nut
  • Loctite 243 glue
For the Z-Axis:
-To come
More info here:
Special thanks to @RobertA_Rieke for the long private chat with me :slight_smile:
Glad to help. :smile:
Here’s the last mod. Z-Axis V-Wheels and Eccentric Nut done.
Easy, quick and reliable.
Will this z axis mod work with the dewalt spindle? Do you have a specific part list. Im about to start assembly this week and want to do all the stiffening mods as i build.
Hello,
yes, it will work with the DeWalt 611, that I already have.
You can find all that you need here:
Phil Johnson Build - #14 (Eccentric nut)
A mod to make z-azix more stiff and easier to adjust (Z Axis mod)
A 30 minute x-axis mod to reduce chatter (X Axis stiffening)
Pretty easy, it requires an hour pretty much. If you want to improve the GT-2 Pulley, you can check my article here GT-2 Pulley upgrade though there are also some other valid mod to make (for sure some of them better than mine)
Al
