so i finally installed my X-controller and after wiring it up i tested it and it worked fine, then after i started up easel it asked me if i wanted to upgrade to version 3.10 (was running 3.7) so i did and now my z axis wont work. X, Y work just fine but not Z. The first time i start up easel i can get a slight twitch from the z when i tell it to go up but then nothing. I bought a new nema 23 stepper thinking thats what it was after checking all the wiring and after installing the new motor still the same issue.
Any ideas or help is greatly appreciated, Thanks in advance.
i have done that as well. when i do that i can get the x to move but not the z no matter what port i plug it into. it was working fine before the update the only thing i have not done yet is tried reverting back to the v3.7 to see if that works again
ill have to try that tomorrow as its to late tonight but as soon as i get home from work ill try that and post what happens.
i usually dont update cause stuff like this happens but the touch plate wasnt working and i wanted to be able to use it which is why i updated and then this… lol
ok so after some more testing i installed v3.7 back again and now all the motors spin like they are suppose to so im at a complete loss as to why this happened or what to do so i can get 3.10 back so i can use the touch plate
When’d you buy your Xcontroller? About a year ago the shipping controllers had an incorrect v1.0c on them. If you upgraded now, it was to v1.1f and your GRBL settings may have been lost in the upgrade. Post your “$$” output here to make sure they’re right.
Yes i would say at the very least it was a year ago i bought the xcarve upgrade kit when if first came out but only now had the time where the machine wasnt making something to install it
im in the USA. i dont use easel to make my parts i only use it to run the machine, i draw and generate the gcode using Aspire then use easel to run the gcode.
