Any interest in a Makita RT0701 spindle mount for X-Carve
I filled out the form / registry weeks ago and still no email either.
I doubt the form itself sends confirmation emails. Probably just a simple way for John to have a google docs spreadsheet or something similar populated with data.
All I wonder is if I actually made it to the list. I would not be surprised if I messed up the form somehow. I’m good at that :smile:
Hang tight guys. I’ve been sick and getting back on my feet has been slower than I would have liked. Shannon, Jeremy, you are both on my list. Ebr, if your name is Endre, then yes, you are also on the list.
-John
Thanks John :+1:
Yup, that is me.
Thanx, John. Get well!
I hope I’m still on the list as well John?
Hope you’re feeling better.
Is the dimension of the Makita around 65mm?
So could I use the mount with a 65mm .8 kw spindle?
Edit: I guess from this forum link, it is 65mm.
I can not find the Makita RT0701 around where I live, but I am looking to get one.
If not then a .8kw 65mm spindle sounds like a good fit for the mount. :slight_smile:
Hope you are feeling better John.
hello John
I’m planning to buy the xcarve, but i want to know if I can change motor spindle, for getting, more power and hopefully less noise, does your makita mount work for this request, 'm in Colombia but the package will be managed to boca raton, thanks in advance.
@JohnScherer - Your Makita moun design mounted to a new Z-axis! Can’t wait to try it.
This z-axis unit from Ebay is like a freaking rock.
You have a link for that z-axis unit?
There are dozens. Go to ebay and search “z axis cnc” This is my 2nd. The first was cheaper and had a stamped metal frame which felt very solid. It literally self destructed. Plus the thread pitch was so fine, I could not get it to move fast enough for complex milling operations. This one has sealed bearings, is 100% serviceable and is rock solid and I can get it moving reliably at 80" per minute (but I use a Gecko controller). http://www.ebay.com/itm/Z-Axis-HEAVY-DUTY-4-5-Fast-Travel-Linear-Slide-Actuator-CNC-Router-Plasma-/161958701097?hash=item25b57da829:g:VkcAAOSwk1JWcW51
Did you have to do anything special to mount it to the X-Carve carriage extrusion and the plate for the Makita router?
Not really. Just clamped John’s plate to the z-axis unit and checked several times for square. Then drilled through Johns plate with four holes leaving a mark on the bearing block on the z-axis. Countersunk the holes on Johns plate. Then drilled and tapped the bearing block. The holes through John’s plate are 1/32" larger than 1/4". This plus the countersink provides a minute amount of adjustment ability for squaring.
Mount it all up, loosen the four 1/4" screws, square it to wasteboard and tighten. Next I resurface my wasteboard with this setup checking for scalloping and fine tune squaring it up…
Oh and mounting the z to the carriage plate is easy. There are plenty of countersunk holes in the back. Again, clamp, square, mark the holes and then drill and tap the x-carve z carriage. These holes were also 1/4" so I used all 8 available. Slight differences in hole positioning among the 8 holes give you the ability to use only 4 screws, and experiment with which 4 give you the best squaring to the rest of the machine. The only down side is having to tap all 8 holes, but when you assemble it, you will be glad you have these options. Different screw patterns will square differently. I had to put a single card stock shim behind the lower part of the unit to square it front to back. I also used thread locker to mount John’s router clamps to the plate because those will be inaccessible once the unit is mounted.
John, I did put my name on your list sometime ago. I am still interested in the mount. :slight_smile:
Ok guys, I’ve sent the email to everyone I have on the list (12 of you). Reply when you can. Thanks for hanging in there. Its been a rough month or so, which I explained in the email.
That is one nice mount Joe! It looks like it could move a house :wink:
By the way, some of you didn’t include a shipping address in the forum. When you reply, let me know where you would like it shipped.
@JohnScherer - Thanks. Can you do me a huge favor? What aluminum alloy are these made from? It machines so much better than 6061 and 3053 that I have been using. I am dying to get my hands on some.
Hello all.
This is my second post here. so consider me a newbie.
I started my first cuts yesterday. I assembled the makita router using cut HDPE as shown and clamp is with latches (bought off ebay). did this assembly as I use the router for other use so it will be handy to remove. I understand that this is not the most effective way to fix the router, but it is working for me now.
Im just sharing this maybe someone could use as an idea; i really think this makita mount being produced here is of much better quality.
thanks,
warren
