ellipse__chandelier.dxf (3.0 MB)
Sorry @JelleVanRegen . I thought I had attached it…
I imported the file into Inkscape, saved it as SVG, then import into Easel
I try to import from Solid Works but have problem with TypeError: First argument must be a string, Buffer, ArrayBuffer, Array, or array-like object.
What is wrong?
When I select the DXF file to Upload, the small preview window (on the right) stays blank and pushing ‘Import’ results in an error.
What am I doing wrong?
DXF import failed: InvalidSignatureException: Signature expired: 20191112T143040Z is now earlier than 20191112T143815Z (20191112T144315Z - 5 min.). Try re-uploading the file or refreshing your browser.
Can you help me with this error message please.
DXF import failed: RequestId: c90a368d-9976-412d-be98-9017a6268b20 Process exited before completing request
can you help me with errorPig core with sidewalls.dxf (65.9 KB)
I don’t know why you’re receiving the error, I opened your file in CorelDraw,saved it as an SVG and then imported it into Easel.
Good Luck
Russell
Hello,
a production version of the app has been released and is now available in Easel.
New questions or comments can be asked in DXF import app 2.0 released thread.
Thank you to all that participated in testing and happy carving!
