Does anyone have the average kWh that the X Carve uses when running a project? Just an average is good.
Chris
Chris
It is actually pretty easy to figure out.
Amps x Volts = Watts
Get that figure for the Router and for your Controller and add them together. Then lets look at a 1 hour run time.
Watts x Time = Watt hours
Watt hours / 1000 = Killowatt hours
Hope that helps (I am a solar guy so I deal with this a lot)
I think the variable is the spindle. How hard is it worked by aggressive feed rates?
To appease my “finance czar” I trip the breaker on the hot tub while in my shop. When I am done, I turn it back on. Consequently, my hobby has a net positive effect on our energy consumption. (that’s the story I am sticking to).
There are two items that draw power when carving:
1 - Xcarve PSU (360W? max)
2 - Dewalt 611 (900W max but rarely achieve this during typical usage)
So 360W+ 900W give you a possible total of 1,26kWh max. I would think the typical consumption would be 50% or slightly less of max, in the 0.5-0.6kWh range.
1.26kWh per hour of run time. (just clarifying your answer for everyone)
In my area that equals out to be about $0.15/hour running time… for Angus it is about $.55(US) (im guessing… I know electricity is expensive down there.)
Wait - WHAT? Niles, Michigan? The City of FOUR Flags? The City of DREAMS? I grew up there. ALL over there. Like in every part of Niles. Are you in Niles now?
Nice - I lived close once on S Third in Potowatami Village. If you haven’t already, check out Pete’s Patio - their pizza and sausage sandwiches are legendary. Notre Dame football in the fall is also a great time. Congratulations on your relo.
Do use a solar generator to power your xcarve ? Thinking about the new jackery .
