Saw this on Amazon:
Patterned Rolling Pin with Cat Design
Wondered what mods would be necessary to get a rotational axis and whether anyone has tried something like that?
Saw this on Amazon:
4th axis would be the “easiest”
a cheap quick way (in theory) would be to make a jig, cut, rotate, cut, rotate. and continue until done. It would be more involved but it would work.
Been done here - but I can’t find it. I believe @ErikJenkins had success. It is on my to do list because I have a system designed for a 4th axis. A quick search for 4th axis on this forum will put you on the right track. There are a few people having pretty amazing results.
Here are my upgrades to a rotary axis:
That is intrepid as hell.
My thing is reproductions of antiquities;
This looks like it would really enable full head sculpture reproductions well.
I have a stock non-upgraded x-carve 1000mm.
I assume I could use that to start the process by cutting the Y-Axis end plates.
did you by chance save the plans for those anywhere?
Did you stiffen the x-axis gantry when you did this, or leave it stock?
really impressive.
thanks for being an inspiration today.
I drilled the X-Axis and installed the steel bar stiffening mod, but I did that not long after I first got my X-Carve.
I will post the files for the taller Y-Axis plates…it might be a day or so…I did them in V-Carve.
I’m building a component spreadsheet and it looks like http://www.camtronics-cnc.com/ is down.
Do you know if Dan has stopped doing this? EBay store appears empty as well…
If they are not available, any ideas where I could buy an equivalent?
Not sure, I had exchanged email with Dan a couple of months ago, I’ll send him one and see if he is still making the controllers.
Here are the taller endplate files and the Y-Axis supports in V-Carve format:
Y-Axis Supports.crv (1.7 MB)
Tall End Plates.crv (2.8 MB)
That is so helpful.
