Looks good! I bet if you could turn the supports for the top on edge it would make it strong enough so you wouldn’t need the center support. Are you going to use the underneath area for storage?
My cart is similar with the middle post. I ended up putting a piece of MDF across the middle to separate it into “front and back”. The back is open, with vacuum and storage, while the front has some drawers and a little more storage.
I put 5 swivel casters on it, one in the middle directly under the post. If I do it right and don’t have big chunks of scrap under the table, I can swivel it around on the middle caster with just one hand.
The bottom piece on the machine just after getting cut. I actually build the 2x4 base and then placed the mdf on top and finished machining…I really love having a 4x8 machine
Here is the finished pocket and I don’t think that I could of gotten it any closer. Keep in mind the mdf was machined and then the 2x4 base was built and then screwed together and then the pocket in the 2x4 was made lol
I have also been experimenting with climb versus conventional milling and actually I machined it like I was machining aluminum…wells sorta…I roughed in climb milling and then finished the last .040" conventional milling and I think that it turned out really good
