I ran into a problem where I set my X and Y off (I set to edge of bit and not center) and I already did a test carve (simple planing of a board) and didn’t want to have to reset the current Z axis depth.
Running through the carve menu will prompt you to either keep current XYZ or reset at the least the Z depth. By following the following steps you can manually set your new X, Y or both without changing your current Z.
- Jog the machine to your new XY.
- Open the Machine menu and click Advanced then the Machine Inspector button.
- In the Console box type in G92 X0 Y0 (this sets position for X & Y to 0)
- Exit out and start your carve. Choose Last Home Position when asked.
