Stand for Signs/ cuttingboards/ books
Hello,
I want to carve simple Stands to present projects. Or as a option for my products, for example to place a sign or cuttingboard.
Has someone already done something like this on the X-carve and want to share it Here?
I found on Google this.
I think it must be an easy carveable stand not a high quality extensive one.
I do alot of flat pack furniture its all pretty easy
slot joints are your friend
@ChristophStieler
@StephenCook posted this … Cool ideas!
and i came across this one …
Maybe you can modify this one for your needs…
@RonSabourin thank you. The craftsmanspace one looks good and easy
I haven’t tried to make it … let me know how it goes if you take a stab at it.
So I think i have all I need…
Thanks @RonSabourin @ShaneBell @B.F
So Here is the topic with svg and dxf for a single stands
After X-mas ill try the stand, then ill post the svg or dxf for this.
Attached you´ll find the dxf and svg file from the “craftsmanspace” book-stand.
It´s made for 6 mm Material, if you need it for another thickness please write me
Teil1.DXF (23,8 KB)
Teil2.DXF (23,8 KB)
thanks
