Really struggling right now. No matter what I cut, my machine is consitently 0.5mm too big. Trying to just make 25mm x 25mm squares, 1mm deep. to test the accuracy
1000mm x 1000mm machine, Makita router dewalt in 2 weeks)
I’ve done everything I can think of:
Belt Tension
V wheel adjustment
Potentiality
Different bits, measuring their diameter
X- axis stiffening mod
Squaring the machine
Checking every screw on the machine
Inside and outside profile cuts.
Pocket cuts
I feel like there must be something really stupid i’m missing. It’s always right around 0.5mm too big. I just don’t get it.
As a side note, if you move your gantry by hand then it will move out of square. Be sure that you only move the gantry with jog controls or if you have to move it by hand then re-square after each time.
I saw quite a long thread about the X carve accuracy. Everyone was changing the steps and at the end it was just set back to the default and it cleared up all their issues. Which is why I’m in two minds about it
Ok. You’ve tried all of the other steps that I’d recommend that you check. Calibration of steps per mm is the next thing to check. If you try it out (it isn’t very hard) you can always put it back if it doesn’t work.
Give it a try and see if it fixes the issue… what do you have to lose?
If you don’t mind. Explain how you went about checking and calibrating your machine.
FYI When I calibrate a CNC machine I do it as follows.
Clamp a 123 block to the table, out close to the center of travel.
Set up a dial test indicator on the carriage.
Move the carriage so the indicator just touches the 123 block in the direction you want to test in. Zero the indicator.
Now issue a move of 3 inches away from the 123 block.
Now very carefully insert a second 123 block in the space between the indicator and the first 123 block.
If you read zero then all is good. If not then you need to adjust your steps per unit until when you run the test again you get a zero reading.
This is the best way to check. You are not relying on eye sight on a ruler to see how far your machine is moving.
As has been stated above if the tension on your belts is changed then you need to recheck because belt stretch will change things.
Oh I did plenty of tests with 1/8 and 1/4 also. Mainly 1/4" too reduce the chance of my reducer collet having an impact on the result. It was all 0.4mm out.
So after calibration it was 0.4mm out consistently in both directions for the 1/4"? What was the actual measurement of the 1/4"? Mine comes in at 6.3mm
