I want to be able to run the two Carvey machines we have in my High School Prototype Lab without the need to have a full blown laptop or desktop computer connected to them. Could anyone help me figure out how to make a raspberry Pi work for controlling the machines.?
I would recommend checking this post Easel Local for Linux? of all the ways to make easel local work it was a much easier solution.
I built a Raspberry Pi Controller for my machine.
You can check my thread on this site and also I have put the first video on youtube (search Ryan Ballard Raspberry Pi and you will find it.)
Ha ha ha ha bobā¦
I have this up and running right now. I use my PI for a lot of different things, one of which is the computer I use for controlling the XCarve. First thing I did to the Raspbian desktop image was install xrtp this enables the pi to be logged in using Microsoft RDP or remote desktop protocol Second, and I didnāt write this but found it and it works, use Sammy Kamkarās solution. Log in to the pi, run the easel-driver.sh and your pi is setup with the driver.
From here you can remote in to your pi desktop and use easel from the raspbian browser chromium that comes with the raspbian desktop.
Hi guys Iāve recently set up my Raspberry Pi 4+ however Iām trying to run my cnc 3018 off the Pi via usb lead into the Pi from the machine. When Iām on Easel it and setting machine settings up it asks me to down Linux, windows or Mac driver so I download the Linux on my Pi open it and when itās extracting the files i get a error message can anyone help me?
@AlexBirkett welcome to the forum.
Have you tried to setup the driver as listed in this post Easel Local for Linux? as stated above.
when you download the Linux driver it is compiled to run on a processor that has the X86 instruction set āthis is a type of processorā
when you download the mac driver is is compiled to run on a PPC instruction set āthis is also a type of processorā
when you follow the directions on the post you will extract the driver source files and compile your own driver for a ARM instruction set āthis is the processor used in the Raspberry Piā only then will you be able to get it to work. ātalk to your systemā the process is steam lined by @SamyKamkar and he has made this very easy to do.
the Pi is a small very efficient system to use for controlling these machines and there is no fan to draw dust into the system. I use mine with a wireless keyboard and love that I can stand directly over the work piece and move the gantry to exactly where I want it.
Hi mate Iāve tried to download SamyKamkar driver but hasnāt been successful. it may be either its been patched now or as Iāve got learning difficulties Iām not understanding it right and doing something wrong⦠is there a video step by step actions or is there a way someone can log onto my Pi and do it for me??
Hello Alex,
I have been struggling with my Raspberry Pi setup as well. Iām at the point where āscreen -r easelā does display some information. Connecting Easel via Chromium still doesnāt connect - kept asking for a USB connection
@AlexBirkett @DwayneK.Johnson can you contact me and allow me to test on your machines to see what the issue could be? I just performed a fresh install of Raspbian + the Easel driver and it worked without making any changes, but perhaps thatās because Iām using Carvey and maybe it shows up differently than the controller youāre using.
Shoot me a private message or way to chat and Iād be happy to look at your system to see whatās going on and improve the driver to automatically work.
@SamyKamkar just wanted to say thanks for all you are doing on this. I believe that you are doing a great job for a much needed driver so that we can use the Raspberry pi on these machines.
Thanks @KennethConnell1, and thanks for helping people as well! Also updated github yesterday to make it a little easier to run with a single copy/paste line.
Btw, are you running Carvey or X-Carve, and what controller are you using? Iād like to update the package to automate whatever inconsistency people are having but Iāve never been able to reproduce it myself so Iām guessing itās a different USB driver for a different microcontroller that people are using.
@SamyKamkar Pretty good chance anyone not using the X-carve or Carvey is using a little 3018. Pretty sure those use a nano clone with a CH-340
Thanks @NeilFerreri1! I found a Nano with CH340 and compiled grbl on it. I donāt have a spare controller to test but hoping this will get me far enough.
Iāve added some debugging and notice that without any code changes to easel-driver, the driver is properly detecting /dev/ttyUSB0 and the Arduino, and itās actually the Easel website that is refusing to āseeā the controller. In fact, this is getting sent to Easel via the WebSocket:
[āportsā, [
{ comName: ā/dev/ttyAMA0ā },
{ comName: ā/dev/ttyUSB0ā,
manufacturer: ā1a86ā,
pnpId: āusb-1a86_USB2.0-Serial-if00-port0ā,
productId: ā7523ā,
vendorId: ā1a86ā
So the question is why is Easel ignoring the data and saying it doesnāt see it. Maybe it expects a specific productId/vendorId/pnpID.
Does someone here have a non-X-Carve/Carvey that is working? If so, in your browser, if you:
- click View->Developer->Developer Tools
- click āNetworkā tab
- click āWSā to limit to WebSocket traffic
- browse to https://easel.inventables.com
- once you see the WebSocket show up, click it
- you should see lines like āget_portsā followed by a āportsā line, click the āportsā line
- expand any collapsed data
- copy and paste that data here
That will help me test what may or may not be getting parsed as ālegitā data from a working controller and then be able to update the code so simulate the controller.
I found the offending code in Easelās website itself. Itās looking for specific USB manufacturer and vendor IDs that CH340 does not respond to
(function() {
EASEL.portUtils = function() {
var b = [āArduinoā, āFTDIā];
var a = [āVID_2341ā, āVID_0403ā, āArduinoā];
For comparison, hereās the get_ports
output of my Carvey which does match:
[āportsā, [
manufacturer: āFTDIā,
pnpId: āusb-FTDI_FT232R_USB_UART_A9048QXY-if00-port0ā,
productId: ā6001ā,
serialNumber: āA9048QXYā,
vendorId: ā0403ā
So to fix this on the easel-driver side, I think we must āspoofā the serial chip and pretend to be an FTDI chip rather than the CH340. Iāve done this by modifying ~/easel-driver/lib/serial_port_controller.js
listPorts function to look like:
var listPorts = function (callback) {
SerialPort.list().then(
function(ports) {
// TODO: scope for callback?
ports.forEach(function(part, i) {
if (this[i].manufacturer === '1a86')
this[i].manufacturer = 'FTDI';
if (this[i].vendorId === '1a86')
this[i].vendorId = '0403';
}, ports);
callback(ports);
function(error) {
// TODO: catch and handle errors
errorHandler.trigger(error);
return null;
@AlexBirkett or @DwayneK.Johnson - could either of you test this modification, then run node iris.js
, then see if Easel works?
HI SamyKamkar on my Xubuntu smth go in right direction after Your modification on serial_port_controler.js i got this on default usb linux driver :
2020-05-07T21:04:50.748Z Websocket Controller [id=4] Client connected via polling
2020-05-07T21:04:50.890Z Websocket Controller [id=4] Client transport changed to websocket
2020-05-07T21:05:00.304Z Machine [id=3] Setting config: GRBL 0.9 Default Configs
2020-05-07T21:05:00.304Z Machine [id=3] Resetting
2020-05-07T21:05:00.308Z Machine [id=3] Opening port: /dev/ttyUSB0
/usr/share/easel-driver/iris/lib/serial_port_controller.js:62
parser: SerialPort.parsers.readline(config.separator),
TypeError: SerialPort.parsers.readline is not a function
at Object.initPortWithConfigs (/usr/share/easel-driver/iris/lib/serial_port_controller.js:62:30)
at Object.initPort (/usr/share/easel-driver/iris/lib/machine.js:597:10)
at Socket.onInitPort (/usr/share/easel-driver/iris/lib/websocket_controller.js:216:13)
at emitOne (events.js:116:13)
at Socket.emit (events.js:211:7)
at /usr/share/easel-driver/iris/node_modules/socket.io/lib/socket.js:503:12
at _combinedTickCallback (internal/process/next_tick.js:131:7)
at process._tickCallback (internal/process/next_tick.js:180:9)
@Hugo Good thing is itās seeing the device. Are you using my easel-driver or Inventablesā? I would make sure youāre using mine first just to reduce variables here.
WORK !!! that error was on Inventables driver than I download Your new driver with install modification i make change in serial_port_controler.js without change port, only listPorts function and now work !! at least
now:
2020-05-07T21:37:14.923Z Websocket Controller [id=4] Client connected via polling
2020-05-07T21:37:15.215Z Websocket Controller [id=4] Client transport changed to websocket
2020-05-07T21:37:24.507Z Machine [id=3] Setting config: GRBL 0.9 Default Configs ( i got grbl 1.1h )
2020-05-07T21:37:24.507Z Machine [id=3] Resetting
2020-05-07T21:37:24.517Z Machine [id=3] Opening port: /dev/ttyUSB0
2020-05-07T21:37:24.534Z Serial port controller [id=2] Port opened
thank You SamyKamar !!
